  • 1 month later...
What I am thinking is that these would fit a US spec 260, no? Anyways, is there a way just to remove the lens? Because I want to leave my lights with the wiring harness and only change out the bottom lenses. Would this be possible? If so, I would be interested in this set. PM me.
Thanks,
Ben
How do the US lights work exactly?
Is the bottom light on when you have the lights on? or does it come on when you hit the brakes? Which lights flash when you are indicating? Top or bottom or both?
If you change the lense only it probabaly wouldn't work the same way that the Non USA cars do.
They have the top light for lights and break, the bottom light is only on when indicating.
