optical dizzy pickup?
Brett240
There is an article on the 280Z build up in the new issue of Sport Z. They are using the distributor out of an 82-83ZX Turbo because it does have the 360 degree optical trigger...and it has 6 windows for the cam signal.
Now they also changed it with one from www.autronic.com as they were having trouble with it having too much resolution to work with their aftermarket ECU... which sounds like it's going to be a wild set up when they get it done...
:devious:
