Posted December 5, 200321 yr comment_59533 could someone tell me how hard and what i have to do to change my air flow meter because i will have to do it myself thank you my car is a 1976 280zx. thank you candy Link to comment https://www.classiczcars.com/forums/topic/9174-air-flow-meter/ Share on other sites More sharing options...
December 5, 200321 yr comment_59534 To just swap one for another is quite simple, only one wiring plug to remove(be careful not to crack the plastic connector or lose the wire that holds it), 4 bolts on the plate underneath and 2 hose clamps. There is one wire that will be attached to one of the hold down bolts that will need to be re-attached.It is advisable to completely remove the rubber boot between the AFM and the throttle body and check for any cracks, any cracks in it, replace it as it will really mess how you engine runs. Also, check the rubber boot between the AFM and the air filter as well.Motorsport Auto has replacements, and MidwestZ should be able to source them as well. Link to comment https://www.classiczcars.com/forums/topic/9174-air-flow-meter/#findComment-59534 Share on other sites More sharing options...
December 5, 200321 yr Author comment_59544 THANK YOU FOR TAKING THE TIME . Happy holidays thank you candy Link to comment https://www.classiczcars.com/forums/topic/9174-air-flow-meter/#findComment-59544 Share on other sites More sharing options...
