My mate is replacing the viscous LSD center in his R32 Skyline with a 2 way Cusco mechanical unit soon. So i was wondering if it's possible to use the viscous center in my R200? What would need to be modified to do it?
  • 2 months later...
Hey Auxilary, wasn't the LSD outa' the Z31's also a VLSD assembly? The SS (Showroom Stock) White 300ZX's that came with the LSD? Or i'm I thinking or otherwise confussing model/year? I believed these to be the VLSD from the factory. :devious:
There is one other thing to remember....
The VLSD has 2 sets of splines in thh 1/2 shafts. The first set engages the carrier & the second set engages the VLSD centre. Hence, the use of 'regular' S30 R200 shafts will result in the VLSD not being used.
My initial suggestion there is to convert to S130 CV axles, but fit the Z31SS or R32 inner CV - assuming it's compatible with the S130 shaft....
That solution is just thinking out loud - I have no idea of the chances of success.
