Posted December 9, 200321 yr comment_60051 Can anyone tell me whether a 5 speed gearbox from a 1979 model 280ZX 2 + 2 will fit a 1985 300ZX? Link to comment https://www.classiczcars.com/forums/topic/9240-will-79-280zx-gearbox-fit-85-300zx/ Share on other sites More sharing options...
December 10, 200321 yr comment_60204 no Link to comment https://www.classiczcars.com/forums/topic/9240-will-79-280zx-gearbox-fit-85-300zx/#findComment-60204 Share on other sites More sharing options...
December 10, 200321 yr comment_60214 The V-6 and L-6 use different bell housings. When using the T-5, from the L-6 Turbo, you would need the V-6 Bell housing and a new "shorter " input shaft.Hope this helps.ecp48 Link to comment https://www.classiczcars.com/forums/topic/9240-will-79-280zx-gearbox-fit-85-300zx/#findComment-60214 Share on other sites More sharing options...
December 10, 200321 yr comment_60247 I thought that the input shafts for the T-5 were the same only the bells had changed, the clutch is the same for the 83 turbo to the 86 turbo.If this is true that shoots my chances of getting a 84-86 T-5 with the better gears.:sleepy: Link to comment https://www.classiczcars.com/forums/topic/9240-will-79-280zx-gearbox-fit-85-300zx/#findComment-60247 Share on other sites More sharing options...
December 18, 200321 yr comment_61116 ZmeFly,I thought the same, but picked up an L6 Bell Housing and put it on the V-6 T-5 and the pilot shaft sticks out 2 or 3 inches (from memory, I'm in Chicago and the tranny is in my garage at home), anyway it was a noticeable/substantial difference.Ed/ecp48. Link to comment https://www.classiczcars.com/forums/topic/9240-will-79-280zx-gearbox-fit-85-300zx/#findComment-61116 Share on other sites More sharing options...
