May 18, 200717 yr comment_209976 Here are some helpful links on the Stroker: http://www.geocities.com/inlinestroker/http://zhome.com/rnt/3.1HanveyProject.htm Link to comment https://www.classiczcars.com/forums/topic/9249-heads-and-l28-blocks/?&page=3#findComment-209976 Share on other sites More sharing options...
May 18, 200717 yr comment_209988 Fuzz260z,Remember that =Enigma= is describing a a left hand drive car as found in the U.S.A. Your block number should be on the passenger side.Somehow I doubt this is the case. All the L6 blocks are the same. Just because the steering wheel is on a different side doesn't mean everything is. I know for a fact that the intake and exhaust are on the same side, so why would the marking on the block be any different? Link to comment https://www.classiczcars.com/forums/topic/9249-heads-and-l28-blocks/?&page=3#findComment-209988 Share on other sites More sharing options...
May 18, 200717 yr comment_209999 You're both talking about the same side of the block. Left side=driver's side on LHD car. Left side=passenger side on RHD car. Link to comment https://www.classiczcars.com/forums/topic/9249-heads-and-l28-blocks/?&page=3#findComment-209999 Share on other sites More sharing options...
May 22, 200717 yr comment_210317 Fuzz260z Yeah i think you meant right side not passenger side. the passenger side to him is your drivers side... And no, its still on the left. Link to comment https://www.classiczcars.com/forums/topic/9249-heads-and-l28-blocks/?&page=3#findComment-210317 Share on other sites More sharing options...
