I've seen this Z in our galleries and now it is on ebay
thefastestz
I think mostly the reason he is only at 14.1 in the 1.4 is more then likely due to traction problems. The car has a lot of go fast goodies on it and is meant to fly.
-3.1 Liter Stroker
89mm Flat Top Pistons
240Z Rods
Maxima Diesel Crank
490 Lift Schneider Cam
Ported and Polished N42 Head
Nissan Comp Swirl Values
44 Triple Webber Carbs with big Jets
Crane Hi 6 Ignition w/ PS91 Coil.
Mallory Distributor
K&N Filter System
Griffin Aluminum Radiator
Maxima 150 amp Alternator
Gear Reduction Starter
High Output Oil Pump
Perma-Cool Electric Fan
Chrome Maxima Valve Cover
Chrome Timing Cover
Billet Water Pump Pulley
Billet Overflow Bottle
Billet Block Off Plates
Billet Oil Cap
Chrome Intake Manifold
Aluminum Radiator Hoses
Optima Yellow Top Battery
Jet Hot 6 to 1 Header with Ultra Muffler
5 Speed Trans
Light Centerforce Flywheel
Centerforce 2 Clutch
3.90 Limited Slip Posi-Rear End
Suspension
Coil-Over Suspension with Camber Plates
All New Urethane Bushings
5 way Tokico Illumina Struts
Front and Rear Strut Bars
Oversized Chromed Swaybars
QuickSteer Knuckles
Body
Full MSA Aero Kit
Shaved Door Handles/Markers and Emblems
All New Rubber Seal Kit
Complete Chromed and Detailed Undercarriage
Fiber Glass Bumpers
H4 Diamond Headlights
Custom Tribal Flame Paint Job
Euro Tail Lights and Euro Clear Front Lenses
Hella Fog Lights
18” Wheels
If you ask me he has a lot of go into it, just need to find out whats making it not go. I think it would be traction.
Brakes
280ZX Master Cylinder
Toyota V6 Style 4 Piston Brakes with 300ZX Rotors
Rear 280ZX Disk Brake Conversion
Stainless Steel Lines
I have read about and talked to many people about the 3.1 stroker. The consensus is that it has to be done 'right' (whatever that is) in order for it to work properly. They talk about overheating problems, they mention that you might not get the gain you would expect from the 300 extra cc's, etc. It seems to me that his list of modifications was designed more to impress rather than perform. I have come across many of these 'highly modified' Z's with blinding chrome and stainless steel that my stock 78 will outrun or at least keep up with. I would be leary about the fact that he is willing to drop 18 grand from his original investment.
Does anyone know how much he has invested into the car? My figure was a guess....
.... nevermind, just found the quote from his Ebay ad:
Up for sale is my 1974 260Z. This is the ULITMATE Zcar. Used as a daily driver for the past year, this car has less than 5000 miles on it. As you can see from the photos I have invested over $30,000 into it.
Why isn't this guy an active member of our club?
Yea, that or he doesn't know how to drive it right .... ?
A car with that much invested, I'd have a tendency to baby it too.
-- M
I don't know why he isn't an active member. I have seen him and his car around town as we do live in the same city but I've never actually spoken to him. I have also seen the car at some of the SoCal Datsun/Nissan shows. Nice car, but for my tastes, a bit overdone.
Exactly my thoughts Stephen.
It's easy to take a stack of parts and pile them onto a chassis, but to get it all to work properly TOGETHER, is quite something else.
If I had all those "goodies" and $$$ in my car and it only did 14.1's, I would NOT be "bragging" those numbers in an auction. I'd be keeping quiet and hoping no one asked!
Somebody correct me if I'm wrong, but isn"t ZmeCruise running 14.1's in a car with substantially less investment than $30K, and significantly closer to stock configuration?
According to his signature he ran a 13.549 @ 101.90 in his 280zx
turbo.
.....and they still call him Zmecruise, that speed is a bit more than cruis'in speeds.......oh well i confess i kinda chuckled too.
  • Who's Online   1 Member, 0 Anonymous, 798 Guests (See full list)
