clutchdust Posted December 21, 2003 Author Share #13 Posted December 21, 2003 na, i'll just get some centerlines or welds made up with the correct offset and bolt pattern but i'll go 17" for tire availability. gotta put Z's on my Z! Link to comment Share on other sites More sharing options...
carguyinok Posted December 21, 2003 Share #14 Posted December 21, 2003 Question I have now is, Would a Ford oil Filter be any Better? Thats a can of worms there There are some that will say no other's that say yes. But you can use the ford part # cross it over to your choice on brand. IMO it just makes life easy knowing the ford filter will always be on the shelf. VS asking for a Datsun part and hope they have it in stock. Link to comment Share on other sites More sharing options...
daddz Posted December 21, 2003 Share #15 Posted December 21, 2003 carguyinok,Is that the FL1-A Motorcraft filter you are referring to? If so, there is comfort in knowing you will always be able to get one and I believe they have an anti-drainback valve built in as well. Link to comment Share on other sites More sharing options...
carguyinok Posted December 21, 2003 Share #16 Posted December 21, 2003 Is that the FL1-A Motorcraft filter you are referring to? If so, there is comfort in knowing you will always be able to get one and I believe they have an anti-drainback valve built in as well. I am not sure, it has been along time since I have been in to get one. It's been over 2 years so.... But that's when I found this out. I was in Autozone looking up parts and found the crossref. on oilfilters. I looked up the number for the Z then used the crossover book and found the ford part#. At that time they had bolth on the shelf. So I put them side by side and there twins. Link to comment Share on other sites More sharing options...
frank13 Posted January 5, 2004 Share #17 Posted January 5, 2004 Hey clutchdust, check out the wheel adapters from Ross Corrigan at www.modern-motorsports.com Every time I see some cheesey honda with really great looking rims I think of these adapters. I mean rims that would look really great on a Z.:devious: Link to comment Share on other sites More sharing options...
