82 L28ET Turbo engine from a 280zx. It has around 80k miles. Gentleman that i bought the engine from did a compression test on the engine and all cylinders had good compression. Ran good. Turbo is blown. Engine, 5spd transmission, driveshaft, wiring harness, afm, ecu, shifter, and other misc parts included. Everything you need to swap the engine, and more. Must pick up. Greenville SC. Email at keith.storm@websitepipeline.com or call.
