De-bugging the fuel Warning Lamp
TomoHawk
Can I get some enlightenment about how the fuel warning lamp operates? I did some stuff with test lamp during summer and found out that one of the wires at the dash light is always hot, so I think there's a switch inside the tank level sender? My warning lamp has never worked yet, even after a couple tank-fuls.I usually fill the tank half-way.
Bad sender maybe? The gauge seems to read correctly.
thx.
happy holi-daze.
That's what I meant.
Oone wire on the warning light is hot, the other one goes to a (switch) inside the fuel level sender that completes the circuit to ground. I just need a confirmation, but that means the fuel level sender isn't working right.
From some drawings I've seen, the fuel level sender actually has to parts (floats&arms), one for fuuel level, the other for the low warning. Just don't know how the low warning part works.
  • 8 months later...
  • Who's Online   2 Members, 0 Anonymous, 920 Guests (See full list)
