Posted December 17, 200321 yr comment_61033 I need the three screws/bolts and nuts that are used to hold the lens cover on for the rear license plate light. I hope this makes sense. If not please let me know and I will post a pic to help. Link to comment https://www.classiczcars.com/forums/topic/9350-screws-from-license-plate-light/ Share on other sites More sharing options...
December 17, 200321 yr comment_61037 How concerned are you with originality? I recently fixed mine using some long machine screws (non metric) and matching nuts which I ground down on a bench grinder to make them small enough to fit in the square plastic holes. Link to comment https://www.classiczcars.com/forums/topic/9350-screws-from-license-plate-light/#findComment-61037 Share on other sites More sharing options...
December 17, 200321 yr Author comment_61073 Originallity...not sooo important Appearance....important With that said, I would want the screws to be black so that they blend in like the originals did. However, I do not own a bench grinder. Link to comment https://www.classiczcars.com/forums/topic/9350-screws-from-license-plate-light/#findComment-61073 Share on other sites More sharing options...
December 18, 200321 yr comment_61142 You can buy the metric nuts and bolts from ACE hardware and paint them black for under $5...RobertH Link to comment https://www.classiczcars.com/forums/topic/9350-screws-from-license-plate-light/#findComment-61142 Share on other sites More sharing options...
