Turbo 4 barrel carb set up
motoracertx
I am looking for any info anyone has on a turbo set-up for a 4-barrel carb system. I have only seen one of these on a car a while ago. I am looking to build something along the same lines as that. But just woundered if anyone had any info or anything like that for sale. Thanks
no, not changing engines out. Staying with the L6. This Z i am going is a 73 240. I have had several and done them each different. I just saw i believe was a Jacobs system once, it just looked interesting. I have a complete turbo motor and all the goodies from a 1983 to put into the car. Just was looking at different options.
One thing I would look at on any single carb system for the L series or any inline 6 in the intake runner length. A lot of these manifolds have unequal length runners - IE shorter in the middle and longer on the ends. This will lean out the 1 and 6 and make 3 and 4 run rich. Not a good solution for a boosted engine. I personally would stay away from that type of arrangement, it lacks the neccessary tuning to compensate for the design. I do seem to remember a turbo tom? setup that was similar to what you are asking about.
IMO The factory turbo setup in much better designed and easily availiable.
  • Who's Online   2 Members, 0 Anonymous, 340 Guests (See full list)
