Posted December 26, 200321 yr comment_61938 I need a new clutch my current one is slipping where can I get one from in Australia that will support 250HP in a 72 240z?I rang one Z specialist here and he wasn't so helpfull so just wondering what I can do? Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/ Share on other sites More sharing options...
December 26, 200321 yr comment_61950 If you were in Brisvegas I'd suggest Albion Clutch Service who do a lot of competition stuff. But seeing you are not I won't. Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-61950 Share on other sites More sharing options...
December 26, 200321 yr comment_61964 http://www.adelaideclutch.com.auDon't mind the webby, they focus their energies on clutches..... Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-61964 Share on other sites More sharing options...
December 26, 200321 yr comment_61994 Hey Gav,Are you interested in a lightened flywheel (about 6.8 kg from memory) it's been balanced together with a R31 pressure plate (more clamping force) & has a R31 clutch plate which is 240mm in diameter as opposed to 225mm standard. This give you more pad area. I have the whole set up with new clutch plate & new bearing for $395.Nick. Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-61994 Share on other sites More sharing options...
December 27, 200321 yr Author comment_62007 What's involved in getting it into a 240z?I wasn't looking at that much for the set up originally but spoke to a mate who was telling me of a very similar set up could be the same deal.Let me know.:classic:Another words I am interested if it's a low fabrication job or no fabrication job. Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-62007 Share on other sites More sharing options...
December 27, 200321 yr comment_62014 As per normal Gav, everything is the same as far as spline, flywheel bolt pattern etc goes.Nick. Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-62014 Share on other sites More sharing options...
February 11, 200421 yr comment_67959 Hey Gav, I am about to get a clutch put in my 240Z that will handle 300 horsepower. Message me if you still need one Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-67959 Share on other sites More sharing options...
February 11, 200421 yr Author comment_67982 Ahh Hello new member thanks for the offer but i took care of the clutch 2months or so ago.I ended up going with A PBR RPM clutch with hardened teeth and heavy duty clutch plate. I also installed a lighter flywheel and have been fairly happy with the current set up.Once again thanks. Link to comment https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/#findComment-67982 Share on other sites More sharing options...
