I need a new clutch my current one is slipping where can I get one from in Australia that will support 250HP in a 72 240z?
I rang one Z specialist here and he wasn't so helpfull so just wondering what I can do?
https://www.classiczcars.com/forums/topic/9465-clutch-suppliers-in-australia/
Hey Gav,
Are you interested in a lightened flywheel (about 6.8 kg from memory) it's been balanced together with a R31 pressure plate (more clamping force) & has a R31 clutch plate which is 240mm in diameter as opposed to 225mm standard. This give you more pad area. I have the whole set up with new clutch plate & new bearing for $395.
Nick.
What's involved in getting it into a 240z?
I wasn't looking at that much for the set up originally but spoke to a mate who was telling me of a very similar set up could be the same deal.
Let me know.:classic:
Another words I am interested if it's a low fabrication job or no fabrication job.
  • 1 month later...
Ahh Hello new member thanks for the offer but i took care of the clutch 2months or so ago.
I ended up going with A PBR RPM clutch with hardened teeth and heavy duty clutch plate. I also installed a lighter flywheel and have been fairly happy with the current set up.
Once again thanks.
