Posted December 28, 200321 yr comment_62108 Hey all there is a little mettle lever or something that looks like one on my 71 its near the ash tray on the sinter of the console nearest the driver seat. can some body tell me what it is. yup i still feel dumb . Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/ Share on other sites More sharing options...
December 28, 200321 yr comment_62110 Originally posted by billramsey2002 Hey all there is a little mettle lever or something that looks like one on my 71 its near the ash tray on the sinter of the console nearest the driver seat. can some body tell me what it is. yup i still feel dumb . From your description, it sounds like the choke lever. Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62110 Share on other sites More sharing options...
December 28, 200321 yr Author comment_62111 thats what im thinking but i donno Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62111 Share on other sites More sharing options...
December 28, 200321 yr comment_62112 See the attached picture. The lever on the left is the choke. The one one the right is a hand throttle, which you will not have. Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62112 Share on other sites More sharing options...
December 28, 200321 yr Author comment_62114 no this ones on the side console but its more than likly the choke lever Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62114 Share on other sites More sharing options...
December 28, 200321 yr Author comment_62115 oops side of the console about 2 inches high Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62115 Share on other sites More sharing options...
December 28, 200321 yr comment_62117 Originally posted by billramsey2002 oops side of the console about 2 inches high Actually on the SIDE of the center console? You got me. I can't come up with anything like that. Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62117 Share on other sites More sharing options...
December 29, 200321 yr comment_62165 Bill:If you have a Late 71, then more than likely you have a 72 Center Console. If so, then the Choke Lever WAS located to the left of the Ash Tray and behind the Shifter.The picture Mark posted is to an EARLY 71 or 70. That Center Console is different in that the Ash Tray is in FRONT of the Shifter and not behind. Additionally, the Ash Tray cover is a flip up on the Early and a Slide Cover for the Late.Now, since you're not familiar with a choke lever, this is a method by which you enrich the fuel mixture WHILE you warm up the car. (The Z tends to be a little bit of a cold wake-up beast.) Once you have the car warmed up, or you're finally moving and don't need the additional fuel, you can let it off. The Hand Throttle that was offered on the Manual 70 and Early 71's was also for warming up the engine, when you needed the throttle and not the additional fuel in the mix. You could also use it as a form of a Cruise Control, except that it didn't have an automatic shut-off if you braked or pressed in the clutch.Hope this helps.Enrique Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62165 Share on other sites More sharing options...
December 29, 200321 yr Author comment_62215 i know what a choke is just didnt know where Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62215 Share on other sites More sharing options...
December 29, 200321 yr Author comment_62216 these cars ar totally knew to me but im learning your advice did help thanks a lot Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62216 Share on other sites More sharing options...
December 29, 200321 yr comment_62225 Bill, That is the choke lever with the black plastic part missing. They (the plastic part) are quite fragile, so no surprise that it's missing. Mark and Enrique; Thanks for solving a mystery for me. I always wondered what the other slot (for the hand throttle) was for on my '72 . Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62225 Share on other sites More sharing options...
December 29, 200321 yr Author comment_62227 yeah its missing you know where i can get another one Link to comment https://www.classiczcars.com/forums/topic/9487-still-learning/#findComment-62227 Share on other sites More sharing options...
