Posted January 1, 200421 yr comment_62487 Dear members,Who can give me answers?in 9/71 the differentail was moved back and a 35mm longerdrive shaft was required. I know this.But what dit they change ? and is it possible too change it at my car aswell? type HLS30-03091 april 1970.I have all kinds off drive shafts 2x 4speed/2x5speed.Thanks a lot Damian. Link to comment https://www.classiczcars.com/forums/topic/9526-changes-from-971-diff/ Share on other sites More sharing options...
January 4, 200421 yr comment_62711 Not quite sure but I think you have to use the later rear mounting bar and front rubber mount. One thing I've found around here is that if you are wrong you soon get corrected. Link to comment https://www.classiczcars.com/forums/topic/9526-changes-from-971-diff/#findComment-62711 Share on other sites More sharing options...
January 4, 200421 yr Author comment_62734 Thank you Richard,I can"t find good information or pictures in books.Is there anyone who can show it by pictures?I looked under the car and still wonder how theymoved the differential 35mm to the back .with other mountings? But are the hanging points on the bottom the same.? Excuses for my charcoal englisch. Link to comment https://www.classiczcars.com/forums/topic/9526-changes-from-971-diff/#findComment-62734 Share on other sites More sharing options...
January 5, 200421 yr comment_62775 Well the differential is located on the front rubber mount and the rear mounting bar which bolts to the back of the diff. Forgot to mention the tailshaft which would be a different length. How about you compare the parts mentioned above to those from a later model, or have a look at a later model? There is/was a Z car club in Holland, too. BTW Damain, your English is better than my Dutch. Link to comment https://www.classiczcars.com/forums/topic/9526-changes-from-971-diff/#findComment-62775 Share on other sites More sharing options...
January 5, 200421 yr Author comment_62794 thanks Richard,I shell look under an 1972 z to see the difference.This is still a problem just a few people know.The reason I want to change it is because Iwant to reduce the vibration problem from the differential axles.Thanks a lot for thinking with me.Damian. Link to comment https://www.classiczcars.com/forums/topic/9526-changes-from-971-diff/#findComment-62794 Share on other sites More sharing options...
