What is the proper procedure for doing the timing on a 1978 280z, in the book it just tells you what the timing is, it does'nt tell you if you have to plug the vaccum advance or anything like that. So could somebody help me, Thanks
https://www.classiczcars.com/forums/topic/9531-timing/
Plug the advance..
Get car at TDC and mark the notch with paint (WHITE
Lossen off the lock nut on the dizzy.
Get car at idle.
Put timing light on crank and adjust.
Tighten up lock nut.
And recheck
If ok connect vacuum advance. If not re adjust.
https://www.classiczcars.com/forums/topic/9531-timing/#findComment-63270
Good point beandip
I would certainly like to know what people are running and what they find best for their applications.
On triples etc most suppliers (Webcon, Pierce etc) recommend cap off the vacuum and advance timing a little to compensate.
Maybe time for a pole
https://www.classiczcars.com/forums/topic/9531-timing/#findComment-63602
  Quote
Originally posted by SteveK
Good point beandip
I would certainly like to know what people are running and what they find best for their applications...........
Would that be the same as a "poll"? LOL
My recollection (don't have my manuals with me at work) is that the vacuum hose should be disconnected and plugged up when setting timing. That is the way I have always done it.
https://www.classiczcars.com/forums/topic/9531-timing/#findComment-63620
