Posted January 5, 200421 yr comment_62838 What exactly is "Turbo Lag". Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/ Share on other sites More sharing options...
January 5, 200421 yr comment_62842 The time it takes the turbo to "spool" up to its max RPM and apply full boost to the intake tract after you open the throttle.Larger turbos normally take longer to spin up to its optimum boost RPM than smaller ones, although, today, the turbos are much more efficient than the ones they used 10 years ago or more.A lot of it has to do with the design and shape of the vanes and impeller in the turbo and how they work together with the shape of the housing.All turbo's will have some lag, as it takes time for the engine RPM's to increase enough to put out the exhaust flow required to speed up the turbo, which in turn will put more pressure or boost into the intake tract. Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-62842 Share on other sites More sharing options...
January 5, 200421 yr Author comment_62846 Thankz 2ManyZ's. That's the info I was looking for. :classic: Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-62846 Share on other sites More sharing options...
January 6, 200421 yr comment_62879 You sure youve never owned a turbo. Hell of a explanation. Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-62879 Share on other sites More sharing options...
January 6, 200421 yr comment_62895 I've driven turbos and even a few supercharged/turbocharged diesels in the last 20 some years...... and I drive a Turbo diesel everyday...... Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-62895 Share on other sites More sharing options...
January 6, 200421 yr comment_62957 When I was at the track there was this huge arse diesel turbo dullie no less that was running in the 13's.Thats just insane.I hear that some of the new OTR rigs have turbos in them now that push up to 50 lbs of boost!!!!!!:cross-eye Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-62957 Share on other sites More sharing options...
January 6, 200421 yr comment_62966 Sequential Twin turbo setups were created to try and overcome the turbo lag problem.The 1st turbo is a smaller one that spools up quickly in the lower rev range to provide some power. this feed into the larger turbo which takes over in the higher rev range when the smaller turbo's wastgate is wide open. Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-62966 Share on other sites More sharing options...
January 6, 200421 yr comment_63003 good article on this:http://auto.howstuffworks.com/turbo.htm Link to comment https://www.classiczcars.com/forums/topic/9579-turbo-lag/#findComment-63003 Share on other sites More sharing options...
