Posted January 7, 200421 yr comment_63179 Wanted - series 1 240z rear hatch vent plastic funnels and attached drain hoses (the ones that fit inside the hatch door directly under the air vents).Need to ship to the UK - full cost paid by me of course.Thanks. Link to comment https://www.classiczcars.com/forums/topic/9618-1970-240z-rear-hatch-vent-plastic/ Share on other sites More sharing options...
January 7, 200421 yr comment_63184 Not sure where you can get the funnels as they are so old. Since the plastic becomes so brittle, they are nearly impossible to remove without rendering them useless. Mainly due to UV damage. Have you tried your local Nissan dealer, it is a long shot but they will have the old parts book somewhere and may be able to order a set from Japan if they have any.As for the drain hoses, you can use any flexipipe with the same ID and OD. Your local electrical wholesaler will carry some betaflex that might be the same dims. Just make sure that you seal the end that attaches to the funnel.You can still get the hatch grills if you need those.If you find a source for new funnels, be sure to return here and let all of us know. Most series one Zed owners will need replacement funnels at some stage.Good luck in your search:classic: Link to comment https://www.classiczcars.com/forums/topic/9618-1970-240z-rear-hatch-vent-plastic/#findComment-63184 Share on other sites More sharing options...
January 7, 200421 yr comment_63198 I need the same part! Any have a couple pairs? Link to comment https://www.classiczcars.com/forums/topic/9618-1970-240z-rear-hatch-vent-plastic/#findComment-63198 Share on other sites More sharing options...
January 7, 200421 yr comment_63204 The last two pairs I saw were on ebay, I spaced bidding on the first pair which were in great shape, and ended up buying a very usable, but not as pretty pair. Can't remember what I paid, but wasn't as astronomical as some Series 1 parts. Good luck, Ill keep an eye out for another pair. Link to comment https://www.classiczcars.com/forums/topic/9618-1970-240z-rear-hatch-vent-plastic/#findComment-63204 Share on other sites More sharing options...
January 8, 200421 yr comment_63224 Yeah, I saw those and got out bid on both. Link to comment https://www.classiczcars.com/forums/topic/9618-1970-240z-rear-hatch-vent-plastic/#findComment-63224 Share on other sites More sharing options...
