Just received Ground control coil over kit for the 240Z.... No instrucitoins?:ermm: Anyone have any idea as to what positon I should mount the threaded sleeve? If you do please provide reference points as well.
thanks
Quentin
https://www.classiczcars.com/forums/topic/9649-coil-overs-please-help/
Hmm, I couldn't find my copy... glad someone had them handy, although, it is kinda hard to read....:ermm:
You'll also find some tips in the Tech articles section
http://www.classiczcars.com/forums/showthread.php?s=&threadid=1200
I am using Tokico Prodra G - not available any more - almost a racing shocks from Japan. Large shafts etc.. :classic: still have a couple of sets of these kicking around NIB if anyone interested...
Q
  • 1 month later...
Not sure how similar the install will be, but on my Talon the perch is about an inch from the bottom of the sleeve, which yields about a 2" lower stance. It has very stiff spring rates though, so it may be a little different.
