Just trying to brainstorm here,
I get a new msa clutch master cylinder, it's been installed for about 2 years.
The black res. cap has never really fit well, and will just slide out if you pull up on it, without any twisting at all.
Looks like a design defect.
I would like to make it seal better....
...has anyone solved this problem?
Thanks in advanced,
Dog
I've had a couple that had loose fitting caps. Try a different diameter O-ring on the cap and it should tighten up the fit considerably. I had one that had an O-ring that was so thin in diameter you could barely notice any difference with or without the O-ring.:ermm:
