Dent in floor of 240Z, do you have that too?
sahunt66
Originally posted by sahunt66
Do you know if that is common? Do you have it on your Z?
Check my gallery for a pic of my floorpan. No dent. It's not the body color anymore as I applied POR15 Rust preventative coating.
EDIT: Guess it didn't get uploaded like I thought. It's done now, should be approved on Sat. 01-24-04 with any luck. Sorry.:(
I really think that it is from jacking the car . A possability here is the ' H ' shaped lifts that are used by some tire dealers. I have seen them use blocks on the front pads so the lift clears the tranny. Not on my car but on others. I had the same raised areas on my car as escanlon said and I could see that a combination of runing over a concrete parking bumper and the use of a floor jack was the cause. I could see scrape marks when I stripped the paint and undercoating. The dents were in the pan about 4 to 6 " back from the start of the upward tilt or the floor. I just pounded the floor down on the drivers side and replaced the floor on the pasinger side. It was rusted too badly.
