  • 4 weeks later...
Right.
the Haynes book says first connect the leads at the gas pedal to see if the switch works, then you should hear the kickdown solenoid clicking inside the trans.
My switch must be rusty, it only seems to kick down sometimes and you have to push the pedal down slow, like when you go around to get on the freeway.
thx.
