I'm repacking the rear wheel bearings. I noticed that the inside bearing is just a regular bearing and should repack fine after I wash it. But my question is about the outer bearing, I noticed that the outside of the bearing is sealed, how do I clean and repack this bearing without destroying the seal?
https://www.classiczcars.com/forums/topic/9763-rear-bearing-repack/
  • 3 weeks later...
Hey Ed, If you've cleaned the bearings and you looked them over for discoloration or gauling/metal transfer, and they are ok from the visual once over. the next step is to actually spin them. If they make any sounds other than quite smooth spinning sounds they are shot! This method of checking bearings is an old timmers "rule of thumb". :devious:
Hey Ed, yes there is an old timmers way of cleaning bearing. If you don not have a solvent tank or a can of real sovlent, what you would use is a can of gas. Like a big coffe can half full of gas. Using the same kind of plastic solvent tank brush to scrube the piece clean. Then blow out carefully with compressed air/ shop air. Or let air dry. Not EPA approved but works real good! :devious:
Recently Browsing 0
