Posted January 17, 200421 yr comment_64704 ok ,yall seem to be the most helpful group of z nuts i've ever had the pleasure of reading from. me being a nut as well i guess i shold know this stuff but, ive never really dealt much with suspension; im more of a stock guy, but the 72 240z i saved is far beyond that already so im taking on my first modidfied project. the insane previous owner heated and cut the origional springs (the car is about 1"- 2" off the ground now) so, being on a limited budget, i purchased some used springs;12" st 103# rear and 11" st 175" fronts. Now, after reading yall's discussions for hours, I am wondering what you would reccomend, remember i'm on a TIGHT budget, I do about my strut situation. I am at a complete loss when it comes to this and any info would be greatly appreciated. By the way, I love the feel of pebbles as I run them over, but I live in the mountains with some bad, but fun, roads. I want it tight but i have to navigate some pretty interesting pot holes.thanks danboone ,nc Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/ Share on other sites More sharing options...
January 17, 200421 yr comment_64721 Its easy enough to change the springs yourself, all you need is a set of spring compressors, a jack, and a socket set to wind up the compressors and to undo the top nut. Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64721 Share on other sites More sharing options...
January 17, 200421 yr comment_64723 Guess i'm not sure what you're asking??Do you mean what struts to install, or whether to change them at all? Did the previous owner change the struts to something that would work with hacked springs?If you need strut inserts- generally KYB are cheapest, or Monroe, etc cheapies.try www.shox.com www.suspension.com or www.rockauto.comGood luck, Jeremiah Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64723 Share on other sites More sharing options...
January 17, 200421 yr Author comment_64739 im gonna need new struts im sure,but do ineed special lenght cartridges to fit my new springsthanks so much for your help Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64739 Share on other sites More sharing options...
January 17, 200421 yr comment_64741 with Suspension Techniques lowering springs, you do not need "special" cartridges. Regular Gabriel, Tokico, KYB, etc will work fine. Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64741 Share on other sites More sharing options...
January 17, 200421 yr Author comment_64742 thanks a ton bud Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64742 Share on other sites More sharing options...
January 17, 200421 yr comment_64744 Just one thing, before you order strut cartridges, you might want to check the strut housings themselves to see if they have been "molested" in any way..... if the car is that close to the ground, he may have shortened the strut housings or moved the lower spring perch......My old race car sat almost that low to the ground (but it depends on where you are taking this measurement also) with shortened struts and adjustable coil overs....Seems to me if the car is that low, with the springs he had on there, there would have been almost no suspension travel at all.There's enough of us here with our cars torn to pieces we can give you the strut housing lengths for stock housings....:cross-eye Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64744 Share on other sites More sharing options...
January 18, 200421 yr comment_64767 Good point Keith. I overlooked his statement about 1" to 2" off the ground. I was just going by the springs mentioned. Link to comment https://www.classiczcars.com/forums/topic/9770-saved-a-z-needs-yoour-suspension-help/#findComment-64767 Share on other sites More sharing options...
