When I press the brakes in I hear air. The brakes are not working good at all. I try to stop and it just slowly stops. Even when Im not driving I still hear the air noise when I press the break.
I had to punch on the brake to avoid rear ending this arse who cut me off and now they are not working properly. Any help would be greatly appreciated.
https://www.classiczcars.com/forums/topic/9785-brakes-giving-me-a-headache/
Sounds like your Brake Booster has failed, or you have a vacuum leak in the hoses/check valve leading to the booster. See if you can track down the location of the leak. If it is th hoses or check valve, it will be a cheap and easy fix. If it is the booster, it won't be very cheap and will be less easy, though not too bad.
