i want to push a lot of power so i can beat my uncles 360 modena in the quarter mile
there aint no way i can get him in the turns but the strait i think i could get him with the proper application to the 240
Check HybirdZ.org for the best advice on a powerplant change.
I'd personally go for an L28ET to get lots more power and it not cost anywhere near as much as a complete conversion.
But if you're going to go the whole hog, as it were, a supercharged chev would haul some serious arse.
Or stay with Nissan and RB26 the sucker, or Quad cam Nissan alloy V8 it.
There's lots of options because of the large engine bay on a Z, but as I said at the start, your best bet would be to check out HybridZ
I have no idea what your uncles car is but are you sure there's no way you could beat him in the corners the Z can be quite a weapon once set up right.
Gav,
i have an idea, it looks like its going to be at least 5000 dollars for the swap.
if you could help me find prices i appreciate it
Depends what country your in and how much work your going to do yourself?
zpictor - it's a 360 Ferrari Modena not Modina - after the place in Italy !
5000 dollars might get you an engine but grow up and face realities - if you want to stop and steer, it's going to cost you a whole lot more !
If you just want to outrun him in a straight line, build a dragster ! Zeds are for taking corners too !
I 've seriously pi**ed off a 328 owner but he had more power than me ...then !
