Posted January 22, 200421 yr comment_65409 I have been looking at replacing the existing SU's on my 73 240 with a Four Barrell Aluminum Intake Manifold from ARIZONA Z CAR and using a Carter AFB #9605 or a Holly 390 600 CFM carb. Has anyone done this and can give me some advice. Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/ Share on other sites More sharing options...
January 22, 200421 yr comment_65413 FWIW, stick with the SU's!!! Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65413 Share on other sites More sharing options...
January 22, 200421 yr comment_65414 A 4 bbl makes perfect sense sitting atop a V8. On an inline 6 it makes NO sense. First the air has to make an immediate 90 degree turn once it's through the carb, and then it has to feed 6 intake ports evenly. And there's no room for a decent-flowing air filter on top of it either. A very poor choice for performance, IMO. Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65414 Share on other sites More sharing options...
January 22, 200421 yr comment_65423 If you search the forums for "holley" or "Arizona Z Car" you'll find the general consence is against this set up in favor of the round top SU'sThis one is an example Boy am I bummed out...terrible dyno results Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65423 Share on other sites More sharing options...
January 23, 200421 yr comment_65438 We have among our datsun kind one person using dual su's on his lil 71 240Z and his 1/4 mile time is faster then mine in a turbo.12.8 compared to 13.5 you tell me why you would want a 4 barrel? Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65438 Share on other sites More sharing options...
January 23, 200421 yr comment_65447 if you have the flat top su units get a set of 3 or 4 screw units and just rebuild them, much better result than the holley or any 4bbl carb set up, good luck:geek: Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65447 Share on other sites More sharing options...
January 23, 200421 yr comment_65453 What they said!:classic: Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65453 Share on other sites More sharing options...
January 23, 200421 yr comment_65457 I'll take everybody's word that SU's are the best, but I have the parts necessary for the 4bbl swap and I'm just curious about how differently the engine would perform....I don't have a whole bunch of hands-on experience on working with engines and I think it'd be a good learning experience. I'm also curious about triple webers: what does everybody have to say about those? Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65457 Share on other sites More sharing options...
January 23, 200421 yr comment_65460 Craig , i have read numerous threads mostly leading to the same ideal, better to sell the parts you have and go with su's 12.9 is hard to beat , the triples are wonderful for a built motor and sound wonderful , but eat alot of gas <if thats a concern of yours> are not cheap to buy and not easy to get tuned correctly. But again they sound wonderful and you have all the gas you could ever need going into the motor, so its your money Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65460 Share on other sites More sharing options...
January 23, 200421 yr comment_65503 What everyone else said except a couple of things to add.Firstly you said you have a 73 right? in the states they are flat tops at this stage correct? If so then you want an earlier set 69-72 carbs. www.ztherapy.com hope that link works good explanation.Tripples are even better and webbers seem to have the biggest bragging right. However they work best on a larger camshaft profile and porting, valve work etc..THey are not worth while without the internal engine work.You can get a Z going 12.8 down the 1/4 with SU's but they will require some work. Boaring out the throats larger needles and seats and you will probably wanna do some porting to the intake manifold also.My opinion don't even consider anything that isn't sidedraft on a straight 6.:classic: PS: 1 other thing F.I is the best especially a multiple throttle body set up. The ZX injection system will probably loose you power over the SU's. But it will be a better DD. Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65503 Share on other sites More sharing options...
January 25, 200421 yr comment_65800 ... about the 4 bbl setup that said the carb sits 90 degrees from normal putting the primaries and secondaries side by side. The floats in this orientation, don't respond well to cornering forces.Also stated that the end 2 cylinders tend to run lean as the end 2 runners have a hard time getting even fuel distribution.I can guaranty ZTherapy's SU's will run like a scolded dog. Too many guys running them on their IT cars & just loving them......... Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-65800 Share on other sites More sharing options...
January 29, 200421 yr comment_66427 I am selling my Bob Sharp Racing intake and Holley 390 4 on ebay. Runs nice on my car!!Go to ebay and do a search for Bob Sharp Holley 4 Link to comment https://www.classiczcars.com/forums/topic/9844-replacing-sidedrafts-with-a-carter-or-holly/#findComment-66427 Share on other sites More sharing options...
