NEW CHILD FORCES SALE !!!
240Z ITS/AUTO-X/NASA/ENDURO $ 4800 obo
MOTOR & DRIVETRAIN
> 240Z engine std bore cylinders honed within spec.
> New rings, rod bearings, & main bearings. (built for ITS)
> Rebuilt 240Z 4-speed “b-box” with new 280Z clutch and pressure plate
> Rebuilt E31 cylinder head (w/ new Cam)
> Rebuilt carbs w/ new fuel lines
> Electronic ignition
> Large Radiator, new hoses, new H2O pump, overflow tank, & Electric fan (on switch)
> New Transmission and Diff mount
> Welded exhaust system
SUSPENSION & TIRES
> Ground Control Coil-Overs w/ Camber kit
> Tokico 5-way adj shocks
> New tie-rod ends & Ball joints
> Front sway bar (rear not installed)
> New Tension Rod Bushings
> New Steering Bushings
> 14x6 Aluminum Race Wheels & Tires (Toyo)
> 14x7 Aluminum Wheels with street tires (For transport to and from events)
BRAKES
> All new calipers, pads, & rotors
> All new drum brakes & shoes
> New steel-braided brake lines
> New Master cylinder
> Disk brake air ducting
SAFETY
> 6 point Autopower bolt-in roll cage
> 15Gal Fuel Cell with fume enclosure w switched electric fuel pump
> 2 Kill-Switches installed (Dash & on Cowl)
> Mounted Fire Extinguisher
> Wrap around Racing Seat
> Window net
> Fresh air plumbing
EXTRAS
> 240Z engine block, Crankshaft, & Head
> Fiberglass rear spoiler (not installed)
> Rear sway bar (not installed)
> Extra coil-over springs (various rates)
> Bunch of other stuff - too much to list.
ALSO HAVE A TRAILER (add $600 to car or $800 by it's self)
> 25' Industrial strength dual axel
> Includes 2 wheel straps & Class 3 ball
> Has a 6’ x 6’ open box for tools, jack, tires, ect…
Car & trailer is located in Northridge, CA
Buyer is responsible for pick-up/delivery service
This car is not currently street legal
https://www.classiczcars.com/forums/topic/9855-for-sale-240z-race-car/
; ipsSettings['maxImageDimensions'] = { width: 1000, height: 750 }; const ipsJsFileMap = [];
