Posted January 23, 200421 yr comment_65563 I started working on my cage last week. After checking with the SCCA on the legality of my main hoop I'm going to get some more work done this weekend before the ice storm. Pictures of my plans, tubing bender/notcher setup and main hoop work can be found at the bottom of the page at this link:EP Cage Build Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/ Share on other sites More sharing options...
January 23, 200421 yr comment_65564 Interesting stuff, especially how the pipe measurements change when you make a bend. Keep the updates and the pictures coming! Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-65564 Share on other sites More sharing options...
March 10, 200421 yr comment_72066 Looks like your into the real fun part there Rick!!!Sorry I have not been around lately -- I have been busy with my house. Hopefully I will get back on my car this summer so I can attend the requisite schools.What made you go EP vs. GT? Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72066 Share on other sites More sharing options...
March 10, 200421 yr comment_72070 Dan, good to see you posting again!!! Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72070 Share on other sites More sharing options...
March 10, 200421 yr comment_72072 I always thought those benders crushed the tube. I guess not. Is that like the Harbor Freight bender? Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72072 Share on other sites More sharing options...
March 10, 200421 yr Author comment_72091 No, this bender is of the $500 variety that makes smooth bends with no distortion of the wall. The tubing is drawn around the die through a mandrel block, not simply pressed like the HF hydaulic benders. Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72091 Share on other sites More sharing options...
March 10, 200421 yr comment_72092 Is that like this one here http://www.trick-tools.com/model_3_bender.htm ? It is hard to see the detail in your pics. Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72092 Share on other sites More sharing options...
March 10, 200421 yr comment_72094 I think that's the same type as Rick has. Here's one that I like, at least for the price.... It also would take up less space in the shop and the price is about in line with the rest of them. They routinely list them on Ebay for about 100 bucks less than what is posted on the web-site too...http://www.toolsplus1.com/eztube.htm Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72094 Share on other sites More sharing options...
March 10, 200421 yr Author comment_72101 Yes. It is pretty much like the manual bender on the page you linked in. I have three sets of dies. I can do 1", 1.5" and 1.75" tubing. Takes a while to get used to the measurements and where to start bending from. My first attempt several years ago took three tries to get a good main hoop. I would love to get the degree wheel option and the hydraulic drive. Link to comment https://www.classiczcars.com/forums/topic/9861-cage-finally-started/#findComment-72101 Share on other sites More sharing options...
