That artical is specifically for installing the Borg-Warner T-5 transmission from a 280ZX Turbo.
To install a FS5C71B from a 280Z and N/A 280ZX,
Find one,
take out the four speed,
put in the 5 speed.
Easy, yes?
Well, that may be a little simplistic. Here's my write-up, when I swapped up to a 5 speed Vic's 5 Speed Adventure
  • 5 weeks later...
I just got my Z today. It is a '75 280 with a 4-speed. I noticed it tachs up to about 4000 rpms at highway speeds. Is it worth swapping in a 5-speed for less wear on the engine? How much better is the mileage? How much does it help with acceleration?
Sorry if this has been covered extensively, but I am a newb to the Z world. I must say, after the 4 hour drive home, I am really starting to love the car... especially since I have finally figured out most of the controls and whatnot.
I don't think it really helps much with acceleration. I have a 1978 280Z that originally had a 5 speed. That trans died so I replaced it with a 82 Maxima 5spd which is the same as a ZX trans. The case is aluminum instead of cast iron and 5th gear is lower. I picked up about 1.1 highway mpg but other than that I don't really notice much difference in normal street driving. Overall, however, I would say the swap is worthwhile. I also went with the 2+2/Turbo clutch.
  • 3 weeks later...
For 5 speeds out of Z's from 77' up to 79' the ratios are all the same as the 4 speed, so if you like your current shift ratios on the four speed, go with the older transmission.
I originally installed a 79' 5-speed in place of my 3 speed automatic. The differential from my automaic is a 3.545 ratio R180. So, my RPMs at 75mph was just a bit over 3100. When I installed an 82' gearbox, the RPMs dropped to 2600. I did lose some punch on the lower end, so I may swap it back until I swap out my motor for an L28.
