Posted January 29, 200421 yr comment_66445 Does anyone have a source for 10MMx1.25 replacement bolts for fastening the Maxima brackets to the rear hubs (14 MM longer than stock) or the bolts to fasten the 300ZX rotors to the hubs on my 280Z (need to be .375 longer due to spacer)All the local sources have a larger head size (not 14MM) or a flange and there isn't space for the larger heads.The only local source, Athens, GA, would not break a box. A source would be greatly appreciated.thanks in advance,Ed Palmer/ecp48 Link to comment https://www.classiczcars.com/forums/topic/9965-fasteners-bolts/ Share on other sites More sharing options...
January 29, 200421 yr comment_66449 Originally posted by ecp48 Does anyone have a source for 10MMx1.25 replacement bolts for fastening the Maxima brackets to the rear hubs (14 MM longer than stock) or the bolts to fasten the 300ZX rotors to the hubs on my 280Z (need to be .375 longer due to spacer) Do you know offhand what the length of the needed bolts would be? In other words, how long are the stock bolts? I might have what you need. Thanks.Chloe Link to comment https://www.classiczcars.com/forums/topic/9965-fasteners-bolts/#findComment-66449 Share on other sites More sharing options...
January 29, 200421 yr Author comment_66456 Chloe,(8) 10mmx1.25 with 14mm Hex at 26mm long. (25MM ok)(8) 10mmx1.25 with 14mm Hex at 35mm long. (1) 10mmx1.25 with 14mm Hex at 60mm long.thanks,Ed Link to comment https://www.classiczcars.com/forums/topic/9965-fasteners-bolts/#findComment-66456 Share on other sites More sharing options...
January 30, 200421 yr comment_66489 You might also try bolt depot: http://www.boltdepot.com/ I just bought a whole bunch of metric bolts from them. They will sell individual bolts, any size or grade. Link to comment https://www.classiczcars.com/forums/topic/9965-fasteners-bolts/#findComment-66489 Share on other sites More sharing options...
January 30, 200421 yr comment_66500 Lawson Products sells bolts with the proper smaller hex head size for Japanese Automobiles. They do have minimum quantity requirements, but these are common size bolts throughout your Z car. I'm sure you could find places to use the few extras. Link to comment https://www.classiczcars.com/forums/topic/9965-fasteners-bolts/#findComment-66500 Share on other sites More sharing options...
