Fasteners (Bolts)
ecp48
Does anyone have a source for 10MMx1.25 replacement bolts for fastening the Maxima brackets to the rear hubs (14 MM longer than stock) or the bolts to fasten the 300ZX rotors to the hubs on my 280Z (need to be .375 longer due to spacer)
All the local sources have a larger head size (not 14MM) or a flange and there isn't space for the larger heads.
The only local source, Athens, GA, would not break a box. A source would be greatly appreciated.
thanks in advance,
Ed Palmer/ecp48
Do you know offhand what the length of the needed bolts would be? In other words, how long are the stock bolts? I might have what you need.
Thanks.
Chloe
