Posted January 29, 200421 yr comment_66471 I just got my 74 260z the other day and while inspecting it I noticed the heat doesn't get hot. So I did some searching on the message board and looked in some of the books I've got. I found some posts on the control cable slipping off the water valves control arm so I went looking. Sure enough I found the cable, intact, just hanging there under the dash, but there doesn't appear to be a water valve at all.Some questions, the valve is usually mounted behind the heater flapper door right? I see the outline of what looks likes the old mounting bracket with two screw holes. The PO mentioned that it needed a new "heater switch", I had assumed he was talking about something on the control panel itself, think he was probably talking about the valve? There is a straight heater hose running right through where I think the valve goes, what would that accomplish? Is it just there to keep the system sealed and leak free? Is installing the new valve simply a matter of doing some careful measuring and cutting the straight hose and installing the valve inline (assuming of course the straight hose was installed in place of the valve)?Thanks for any help! Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/ Share on other sites More sharing options...
January 30, 200421 yr comment_66486 Sounds as though they plumbed it direct without a valve, so your heat is "always" on. Then again that you still haven't noticed any heat, makes me wonder if it's heating up to temp.2¢Enrique Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-66486 Share on other sites More sharing options...
January 30, 200421 yr comment_66496 Are the actual heater hoses from and to the engine block intact and functional? Are they carring water to and from the heater core? Or is it bypassed? Like Enrique said if all the above is good and true, the water pump would constantly be pumping the coolant through your heater core. Constant heat. Does your engine run at a normal operating temp? Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-66496 Share on other sites More sharing options...
January 31, 200421 yr comment_66574 Do you have air conditioning or just the basic ventalation system? It could be one or three ... of three things Hoses Heater **** Water Vacuum ****.. I just rebuilt the entire thing in there.... it sucked Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-66574 Share on other sites More sharing options...
January 31, 200421 yr Author comment_66627 It is just the basic ventalation system. I think I'm going to rebuild everything from the firewall back in the passanger cabin. I'm going to replace the heater core while I have it all ripped apart just as a precaution.Thanks! Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-66627 Share on other sites More sharing options...
August 4, 200420 yr comment_89830 I found a vacuum hose marked "W" on the end. Is that supposed to go to the water valve? If it does, where is the vacuum tap for the water valve supposed to be?Right now, I think my heater is stuck on v'vent' so I think another vacuum hose fell off the control valve thingy.thx Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-89830 Share on other sites More sharing options...
August 6, 200420 yr comment_90017 This might help you out.. a little bit Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-90017 Share on other sites More sharing options...
August 6, 200420 yr comment_90021 The pictures provided by PrOxLaMuS are great, but will only help if your 260Z is of the "LATE" type. 240Z's and EARLY 260Z's didn't have all that stuff, just a simple water control valve and 3 hoses. Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-90021 Share on other sites More sharing options...
August 6, 200420 yr comment_90022 :stupid: :sleepy: Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-90022 Share on other sites More sharing options...
August 6, 200420 yr comment_90044 Hey All, I know this will shock some of the purists but I put a Mack Truck water valve in my 72. It works good and matches up with the stock cable. Part number is 25mf213. Costs around $13. Chris Here's a pic. Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-90044 Share on other sites More sharing options...
August 6, 200420 yr comment_90067 ChrisA said: Hey All, I know this will shock some of the purists but I put a Mack Truck water valve in my 72. It works good and matches up with the stock cable. Part number is 25mf213. Costs around $13. Let's see now, your car has a Mack Speedo cable, and Heater valve, I've got a feeling the Bulldog Hood Ornament and Air Horn must have been on back order! Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-90067 Share on other sites More sharing options...
August 6, 200420 yr comment_90068 Bambikiller240 said: Let's see now, your car has a Mack Speedo cable, and Heater valve, I've got a feeling the Bulldog Hood Ornament and Air Horn must have been on back order! The silver dog is $50.00, the gold dog is $70--how many would you like Carl? :laugh: Chris Oh, you'd be amazed how many people around here have them on their pickups!! :stupid: Link to comment https://www.classiczcars.com/forums/topic/9970-heater-water-valve/#findComment-90068 Share on other sites More sharing options...
