But you would have to fashion mounts and the like for the motor and the transmission.
The rear wont be a problem though.
If your looking for just getting a turbo into your car it would be easier and a LOT LESS costly to go with the L28ET out of a 280ZXT.
Either way you decide good luck and do take a look at HybridZ.org, a good place for people doing converts to the Z and ZX.
without custom manifolds, the turbo placement will foul the chassis rail on the LHS. I have seen people notch the rail, but a better solution (engineering-wise) is to make custom manifolds.
They are a small engine will plenty of power; a good balance.
But Zmefly is right - the L-block turbo is a much easier fit!
