I think you should hold off on rims until you get the flares on due to the fact that a big bit of metal has to be cut from the rear arch in order to fit the flares on properly and allow a bigger sized rim on there.
I gave you the offset previously for the Watanabe rims on a stock C110, did you want to know the offset for a GTR? (flared C110)
https://www.classiczcars.com/topic/10052-offset-for-240k/#findComment-67547
