Originally posted by billramsey2002
hey im woundering would a 5 speed trans from a 83 280zx fit a 71 240? if so what would i have to change.
If you have a Series II 240, then you won't have to switch hardly anything at all. Maybe check out the dimension from tranny tailshaft to diff. flange. But I don't think you'll have any problems.
If you have a Series I 240, then you'll probably end up swapping consoles, driveshaft, & tranny mount.
Other than these things, it's a bolt up swap that takes no more time than pulling/installing the stock tranny.
https://www.classiczcars.com/topic/10077-trans-swap/#findComment-67358
Hi,
We've just been having this discussion in the UK:
http://www.zclub.net/forum/showthread.php?s=&threadid=1501
Seems like the outcome is an '83 box should fit but you'll have to bend the gear shift lever whereas a '78-'81 box doesn't.
Cheers,
Rob
https://www.classiczcars.com/topic/10077-trans-swap/#findComment-67361
