Loss of power after high speed run
Another huge difference I have noted since doing the valves is how well I starts! Previously when cold it'd turn over for say 2-3 seconds before spluttering into life, then I'd have to hold it at say 1500-2000 rpm for about a minute if I didn't want it to just die on me.
Now, it just instantly fires into life with a much more "fruity" note, and will idle immediately. It feels a bit stronger in the top end now, but the huge difference is the low end and mid range torque! It pulls so effortlessly at lower RPM now. It's like driving a different car. :)
Interesting.. maybe I should do mine when I get some time. My K used to start first time with half a crank, but since I changed to dual SU's I need to use the choke at first if I don't want to be cranking over and over and over.
  • Who's Online   1 Member, 0 Anonymous, 1,318 Guests (See full list)
