Hi Everyone,
Question, rod n rod caps, are the notches on the same side or opposite?
Got my engine balanced and the rods came back with numbers but some have notches on same side and others have them on the opposite side. Checked with book and it doesn't mention any place about orientation.
Thanks a Mill,
https://www.classiczcars.com/topic/1025-rod-n-rod-caps/
The only notches I can think of are on the pistons. Or do you mean the squirt holes on the cap?? Notches on the pistons all face the front of the block, the cap and rod numbers have to agree and in the same cylinder number and the squirt holes should all be on the same side. I believe the squirt holes should all be on the side opposite the oil filter. Hope that helps.
https://www.classiczcars.com/topic/1025-rod-n-rod-caps/#findComment-3602
