I found a thread that gave this information
heat range for the L series engine (not full race) cool BPR7ES, warm BPR6ES, hot BPR5ES, the variables are condition and usage
What I need to know is I have a stock L24 with an E31 head. I have blow-by on cyl 5, and my compression is as follows from cyl 1 to 6: 120, 120, 120, 120, 40, 120. My rear carb will not tune quite right, it runs rich all the time (probably needs rebuilt) but the front carb is in good tune. I just need a 'short term' solution here since I'll be replacing the engine this year (I hope). What plug would be best for my car? The plugs always seem to foul so I will end up replacing them on a regular basis after doing some driving then letting it sit for a while, or doing a lot of driving. So really expensive plugs, like $8/each, are a bad choice unless they will not foul (yeah, right).
Any help on this would be great!! Thanx guys & gals!! :classic:
https://www.classiczcars.com/topic/10452-ngk-plug-questions/
  • Who's Online   2 Members, 0 Anonymous, 1,527 Guests (See full list)
