Hi Vicky, I bought a 72 and it had been hit in the front so bad that the seam you described on my car's right side had split and had a quarter inch gap under the previous owners crappy repair job. When the hatch was closed you could see through the gap from the body being sprung. I suspect that is where the factory welded the roof on.
https://www.classiczcars.com/topic/10538-is-that-a-seam/#findComment-71046
Vicky,
Yes probably as my parts fiche lists superceed numbers up to 12 / 79. It gets quite confusing, but just dealing with the right side of the car, and both inner and outer panels are involved, the outer panels are:
73120-E4100 - roof panel
73270-E4100 - tail rail
78100-E4600 - rear fender
There are a number of inner panels as well as a corner brace involved that make up the box section through that area. I could look, but I'll bet there is an inner panel seam to match the outer. In my Chassis and Body Service Manual, this area is described through section E-E of Figure BF-59 "Sealing Body Panel Joint" and appears on page BF-31. Of course, this is all early series information, but it seems to be all the same up to 1979.
I have had this area down to bare metal before and the seam in Her Majesty is filled with lead. It does crack and heating the area is done to fill it again.
https://www.classiczcars.com/topic/10538-is-that-a-seam/#findComment-71177
  • Who's Online   2 Members, 1 Anonymous, 1,413 Guests (See full list)
