If you are referring to the RED car at the top left, then the headlights are the standard all 72-78 Z headlights. The Side Markers are also standard for the same years. The "turn" signals you see below and on the bumper I think are actually a pair of AMBER FOG lamps. The bumper makes it hard to detect if the standard turn/park lights are below the headlight buckets.
The White Car (behind the chicks, and your power of concentration is amazing) has the same style of headlights and side marker lights. You CAN see the turn / park lights below the bumper and the headlight bucket. Whether the car has fog lamps or not is not noticeable. The car DOES have the Bumper Overriders or Bumperettes mounted both front and rear whereas the Red car does not.
If you are talking about the Ladies that are superimposed over the white car, and assuming that by "Headlights" you mean the same thing as I do, then find your local girlfriend and she should have a set you can play with. If that is not an option and you must absolutely have a pair, if I recall you can get a pair of your very own for about $3-4,000 depending on size. :cheeky:
If on the other hand, you are referring to a completely different set of headlights, could you explain?
Enrique
orange car in zcar club logo
look at the headlight buckets it looks like there is 2 lights in it! one is the usual 5inch light and towards the hood top grill there is a smaller light looking to either be a city ligth or turn signal
it's right at the corner of the fender and hood end
makes the car look like it has 4 eyes
Those are reflections of light from the original picture.
Look at these pictures of That Ozzy Guy's Featured Car and you'll see a similar reflection:
http://www.classiczcars.com/photopost/showphoto.php?photo=9353&password=&sort=7&thecat=500
http://www.classiczcars.com/photopost/showphoto.php?photo=4160&password=&sort=7&thecat=500
As far as I know, there isn't any kind of light available off the shelf to do what you are referring to.
Hope this helps.
Enrique Scanlon
ok kewl so then it's just a reflection or someone did a custom job.
looks like I plan to make my own custom buckets for lights
I think i should go hella hid's with inner city lights
thinking these
http://www.hellausa.com/maineng/NewLook/ProdServ/perflighting/90mm_module.html
1 on each side on the outside and then a simple inner city light giving the effect of dual eyes
  • Who's Online   1 Member, 0 Anonymous, 1,300 Guests (See full list)
