My F 54/turbo building project is ready for internal parts. Top End Performance offers a complete "engine rebuild package" for $1895.00. Is this a good deal? Can anyone recommend another supplier with better service or prices? I would like to hear from others who have done business with Top End Performance and their opinions. Thanks for your help. mayolives@aol.com
https://www.classiczcars.com/topic/10715-top-end-performance-parts/
That seems way to expensive! But then again what does it come with? I rebuilt my L24 and E88 head for about $800 US and that's with the machine shop work and new everything exept crank rods and pistons. so if you're getting all new rods pistons crank block rings bearings head cam springs timing change all gaskets and freez plugs and anything else needed for a "new" L28 I guess its not that over priced. It all depends on what your getting.
Matt-
Here is what Top End's web site offers:
Z Car Turbo and High Compression N/A Performance Engine Rebuild Package:
Everything you need to build a kick-arse Normally aspirated or Turbo engine in 1 box.
JE Forged Piston Set with JE Rings,(Your choice of Bore Size, Stroke, and Compression Ratio )Clevite77 Rod and Main Bearings, 44mm and 35mm Stainless Steel Intake and Exhaust valves, Dual Race Valve Springs, TEP Performance Camshaft (Your choice of Grind), Complete Timing Gear Set, Turbo Oil-Pump with Dual Relief springs, ARP Head Stud Set, ARP Rod Bolt Set, Full Gasket set with METAL 1.0mm or 2.0mm Head Gasket...
$1895.00
$1895.00
I just ordered a suspension kit from TEP a couple of weeks ago. Everything worked out great. They definately have some nice performance upgrades. The only dissapointing thing was the package didn't arrive soon enough. All was forgotten the day UPS finally arrived! The engine overhaul kit they offer is definately a great setup. Get that kit with the proper machine work and you'll be smokin. I was going to go that route before I got a great deal on a 82 turbo. Good luck
For the members living in and around So. Cal Tep is in north hollywood. They have a in house machine shop and everything done by them is performance. If you check www.racetep.com , Go to the datsun Z section, look for the engine asssembly work available with the $ amount for different machine work.
:devious:
  • 4 months later...
Out of interest, is that kit list on their site anywhere? I don't seem to be able to find it, just the individual parts. Seems like a very good price for the parts you get.
Damn, you guys in the US are lucky!!!
Cheers,
Rob
I just finished rebuilding an engine, so I punched some numbers in for the items you described. Then I cruised the site and punched in the numbers for the pistons, timing set, etc... and came up with $1759 - pretty close. I'ld say it was a good deal.
  • Who's Online   2 Members, 0 Anonymous, 1,042 Guests (See full list)
