If the bumper shocks don't have any spring action, then your bumpers are totally useless. Before, the shocks allowed the bumper to take a light bump (5 MPH) without damage. So now, if your bumper shocks have no spring, then the force of an impace goes straight into the body/frame, or the shocks themselves will get squashed like a pop can.
A better option would be to get shorter bumper shocks, but then you still run the risk of bending the sheetmetal if you get bumped because the bumpers are too close with no room to move.
Uh Oh, you got one of those bars with the pivotting ends...
Those bars don't help you much, because the pivots still allow the suspension to flex, like a wobbly rectangle-- it just keeps the geometry the same. One with rigid ends is better.
No mater how hard you tighten the nuts, they're still too lose when you flex the 2400 lb. car ( did you put 2000 ft-lbs of torque on the bolts?) Really... Maybe later on you could weld in a gusset to your properly-adjusted bar to permanently set the ends, then chrome/paint everything.
Then again, for $8 you could buy a steel pipe and make one that's just as functional.
Actually, the best way to make it really rigid would be to run a bar from the frame rail on one side to the top of the strut on the other (diagonally), then the other way. That way there's no way things could flex. The hubs would have to break off!
Isn't the engine in the way?
Originally posted by wolf66
Well it was this or take em off....and the shocks action won't do diddly in a high speed rear ending, it was only in the Fed 5 mph
crash test that it was useful, and i don't back into stuff.
I assume you drained them to get them to collapse. Maybe you could cut them a little shorter and stick a spring (motorcycle shock?) in there for some some minimal protection.
Does look much better tho.
You get what you pay for. Remember, those bars that Megan Racing or whatever ebay name they use are for a Honda Civic, they're cheap and they are basically for looks.
