alright im getting the motorsport aerospace coated header for my 75 280z with FI and was wondering since the egr will no longer be able to connect into the exhaust system will the car still run? or does that mess up the computer somehow so that it wont run?i dont have any idea and its really bothering me so any info would be great thanks
https://www.classiczcars.com/topic/10734-egr-valve-question/
My 78 has a header on it and the EGR valve doesn't have the tube on it. I don't know why theEGR valve is still on there. I think I'll take it off and J.B. weld a plate over the hole. Same with the thermal vacuum valve and the baqckpressure transducer valve. I don't know what they do tho.
well when i took my car in for a diagnostic nissan said it was running too rich already and i dont know anything about FI so i didnt know how to change it but anyway so if you leave the egr on it the car will still run even tho the egr goes nowehre thats nice to know and if you try taking the egr off and plugging that hole on the manifold tell me what happens thanks for the info, oh yeah back to the runnning rich thing how do i correct that?
When I got my engine the look-over at the dealer, he said "you're running rich" (off the scale!?) You can do these things:
1. Replace the AFM (obviously not working)
2. If not the AFM, then replacethe wiring for the engine.
3. If not #2, then replace EVERYTHING.
The AFM from the edealer runs $600 installed. No guarantee that it will fix the problem, either.
egr reciculates exhaust gas back into the intake after the mafs so it doesnt affect ur air/fuel readings. The egr opens up at a certain tempurature to lower temperatures in the combustion chambers to keep the nox level low. It is for emissions and the egr on our cars dont have any electronics hooked up to it so the computer doesnt work with it. It works on vaccum. and thats wat the thermalvaccum valve is for. at a certain temperature. it opens up and allows vaccum to the egr and opens it up.
Wont be a problem to remove it and plug it up. Because its jus a hole in the manifold w/o the egr there. When u push up on the diaphram on the egr, it opens the valve so that exhaust gas gets thru to the manifold, thats wat causes it to want to die out.
So if you took the EGR tube from the exh. manifold and had fresh air go into it, then it would be OK? I think mine might already be sucking in the hot air from the engine compartment (no EGR tube is there).
I would have to drain some coolant to remove the thermal vac. sensor, & then plug that?
thx.
You can just disconnect the vaccum lines that go from the egr to the manifold. That way the egr never opens. Then jus plug that vaccum line and it should fine. Im tryin to completely remove my egr to make the enginebay look a little less messy. Im either gonna plug the coolant lines or jus bypass the themalvaccum valve.
Me too.
It means less metal to clean & polish, more room to work, it'll stay cooler & I might even blast the word "Ferrari" on the intake & rocker box! LOL
Wait-- If there aren't enough gadets & thingys on the engine, do you think the "Emmissions Police" will get suspicious? LOL
