Bad260Z,
17" wheels work just fine on the Z car. If you have a stock spring setup you will likely need to stay with a 7" wide wheel. Any wider and you will likely need to convert to a coilover setup. Basically, the coilover setup uses a smaller diameter spring which allows for a wider wheel. You will have offset to consider as well. A stock issue Z wheel has a "0" offset. Since most of the 17" wheels are designed for front wheel drive cars and have built in offset, you will likely need to use spacers to compensate for the offset in the 17" wheels. Hope this steers you in the right direction. Also, you may want to browse the site's forum archives for posts on this subject .
  • Who's Online   2 Members, 0 Anonymous, 1,404 Guests (See full list)
