Okay folks, I got the 73 out of winter storage and drove it today. I primed the oiling system first then fired her up. As I was driving I noticed a puff of smoke out the exhaust in between shifts. Anyone have a guess as to where the oil is getting in at. I would guess a valve stem seal. Havent run a compression check yet. Car was great before put away for winter. All gauges good while running. Could it be a PVC valve issue pulling some weird issue under the valve cover? No smoke while idling or under throttle in any gear, just between shifts.
Thanks in advance.
https://www.classiczcars.com/topic/10832-puff-of-smoke/
  • Who's Online   1 Member, 0 Anonymous, 786 Guests (See full list)
