Im in the process of buying 240z, plz help!
the basic diffrence in the 240 /260 and 280 motors is size in liters the 240 being 2.4 liters and so on , but the carbs are key on the motors the best being the 4 screw round tops su's and the 3 screw round top su's basicly the same , the 260 and 73 240 had a flat top hitachi which are not recommended , or you had the 280z fuel injection which has its pros as well , some people prefer the su's and some prefer the FI but as far as the basic block set it its mainly size , good luck , check for the cancer all over the car , floor pans rails and under the battery tray , also under the hatch , :geek:
zaka,
hi, welcome to the site, people here will be able to help with virtually any questions you may have.
Does the body number start off HS30- or S30- or even RS30-, hopefully it is the first one. telling you it is an export right hand drive 240z. do you have a compliance plate fitted. if so it was delivered at the date on it in AUS. If you can tell me things like body number and engine number on the manufacturers data plate I should be able to tell you the age.
are you really in SYDNEY area or outside in the country, I am up near Newcastle and if your close enough maybe I could help you to check it over sometimes it may save you or at least let you know what you getting into.
let us know
cheers
Steve
yer man im from penrith, i actually live in a little suburb called erskine park,but not far form penrith! i dont actually know the engine number or ne ting, hopefully buy it reel soon, yer man thatll be great if we meet up!!!! if u got msn, add me, my email is zaka_da_sk8y@hotmail.com!!!! later champ!!!
In answer to your question. Yes they are.
How much you paying for it?
What happened to the L24?
Check it very carefully for rust.
Bring a camera and take photos of anything you think might be a problem, and put them up here and people will be glad to give you their advice.
Hey sjcurtis,
What's a RS30? One of our members at wazcars.com has one. It's a 260z. Whats the R for . All 260z ive seen are GRS30's
Hi Zaka,
I know Erskin Park well, I used to live in penrith when Zeds where new. Hope you managed to talk the guy down. I got to agree with Mr Camouflage be very carefull about the rust. There are lots of Zeds around you, and they do come up for sale, so be sure it is good. Cant wit to see some photos when you get it home.
good luck.
Steve:classic:
