Hey Z people,
Can anyone out there tell me how much torque I can expect to get from this set up...
N42 head
F54 flat top pistons
HKS 2mm head gasket
Header 6-2 with a 21/2 inch exaust
SU carbs with SM needles
Electronic dizzy
I should be running about a 9.1 :1 compression ratio
Im not looking for exact numbers here im just interested in a ball park torque number. If anyone has ever dynoed a setup like this, that would be awsome.
Thanks, Matt
https://www.classiczcars.com/topic/10901-f54-torque/
thanks guys that's the info i was looking for. Bruce, shouldn't your RWHP be a lot more than 114? With 212 ft lbs of torque I would think you would have somewhere around 180 RWHP:ermm:
Right on dude's
P.S. Bruce, do you have a dyno sheet I can take a look at?
https://www.classiczcars.com/topic/10901-f54-torque/#findComment-74186
