240ZMan Posted March 30, 2004 Author Share #13 Posted March 30, 2004 Just got my block back and the broken bolt is gone. There isn't a trace I can see. I ran a stud in and it goes in smooth, and still feels tight.The bad news, if you can call it bad news, is that it cost $110. But in the scheme of building up a motor, I guess that isn't too bad.Best of luck to you, 1975yellowBSPZ. Since my block was already out of the car, I took advantage of it. I hope it doesn't get to that for you. Link to comment https://www.classiczcars.com/topic/10975-broken-head-bolt/?page=2#findComment-74878 Share on other sites More sharing options...
st0878 Posted March 31, 2004 Share #14 Posted March 31, 2004 Be careful not to use too much oil when reinstalling a bolt to the block/head. A few drops of oil with nowhere to go can turn into a hydraulic pump and fire through or crack a block. Link to comment https://www.classiczcars.com/topic/10975-broken-head-bolt/?page=2#findComment-74896 Share on other sites More sharing options...
SteveK Posted March 31, 2004 Share #15 Posted March 31, 2004 240ZMan What you have described sounds like "spark erosion" and has been used successfully to get many an engineer of of the poo, many moons ago (1980's) I worked for the British National Coal board, where very heavy engineering was the norm, a colleague of mine broke a 1 inch tap off in a cast iron casting which weighed half a ton and cost in excess of £10,000 - then -- boy was he glad of spark erosion. st0878 Its a very good point and something to be conscious of, personal preference is to use the copper type grease's as they will stay in the threads and don’t "pool" so readily Phred I did like your method M8 -- never occured to me :stupid: Link to comment https://www.classiczcars.com/topic/10975-broken-head-bolt/?page=2#findComment-74956 Share on other sites More sharing options...
peterc Posted March 31, 2004 Share #16 Posted March 31, 2004 Great thread. I think most of us have had (or eventually will have) this problem happen to them. And once you've solved the problem using anti-sieze to prevent a future occurance is a no brainer. And Phil, if you can fit a nut onto the broken bolt welding it through the middle is truly a great idea. I'm almost looking forward to it happeneing again, just for the satisfaction of being able to wind that sucker out ROFL Cheers, Peter Link to comment https://www.classiczcars.com/topic/10975-broken-head-bolt/?page=2#findComment-74992 Share on other sites More sharing options...
240ZMan Posted March 31, 2004 Author Share #17 Posted March 31, 2004 While we're on this subject, I have another question. We're fortunate in the Denver area to have a guy whose entire business is working on Zs. He has been a great source of information and advice to me. When I called him about the broken bolt, he said he didn't know as he had never broken one. At first I thought he was kidding, but he was serious. And I'd have to guess he has removed literally hundreds of heads. I broke a bolt on my second!So my question is what "tricks" are there to taking the head off? I think I followed everything I've read in books, but as we all know, there is a lot that isn't in books:stupid: Link to comment https://www.classiczcars.com/topic/10975-broken-head-bolt/?page=2#findComment-74994 Share on other sites More sharing options...
